Basically when the car is upto operating temps and I pull up to stop the revs will die and will almost cut out the engine.
Whats is the cure as apparently its a common problem.
the car is a 92 Eunos roadster.
Will the idle control valve need to be reset?
Do I need to spray loadsa carb cleaner into the intake manifold?
Have I got a blocked fuel filter?
