I started removing the header and manifold but they arent coming off. Thats why I was wondering if theres a thread that shows where all the bolts and nuts are, so I dont have to find out the hard wayits pretty simple. remove the intake manifold and the headers. take off the valve cover, take off the bolts inside the head holding on to the block. pull it off and send it to a machine shop to get resurfaced. and now all you would really need is the torque specs and bolt pattern. and put everything back together
Thanks I'll do that. Any other good tips/suggestions?I'd suggest spraying it with copper spray before you reassemble. The copper spray will help fill in any fine imperfections in the head/block surface.
Just find the bolts/nuts holding the intake manifold on and unscrew them.
Any more tips or recommendations? I cant seem to take off the intake manifold
[/QUOTE
This should help
]http://www.miata.net/garage/manifold/index.html
