Hello all!
I have a couple of questions about the Jenvey ITB kit. I have the rev9 kit with IAC 4 port block, throttle linkage, fuel rail, and sausage filter with backing plate. I'm running on a MSPNP2 on my 1992 1.6 NA.
1.) IAC:
First and foremost, is anyone here running IAC?
The kit came with this vacuum block: http://www.jenvey.co.uk/home/access...dynamics/air-control-valve-kit-4-ports-avk2t2Air-control-valve-kit 4-ports-avk2t2
This accepts a 19mm tube, so I figure I could plumb tubing to it. The valve I was thinking about using is the 'Idle Air Control Body for use with Jeep 4.0l IAC Valve' from diyautotune and use the proper stepper valve. I would mount the block somewhere, and run the intake from the back of the sausage filter plate, and the output to the 4 port block. Am I on the right track? Any pointers for MSPNP2 IAC settings in this application?
2.) Assorted Hardware for installation:
So I read that the stock block has a couple of studs that hold the intake manifold on. These have to be swapped for bolts to fit the manifold. What are the OEM bolts and how many do I need to get?
3.) Vacuum block:
I love STOLY's setup with the golden eagle vacuum block mounted to the old washer bottle bracket and I'm going to copy the $#!^ out of it.
What stainless steel lines are these (size etc)? What size tap to the bottom of the manifold, and what hardware/fittings are used all around?
4.) Brake Booster:
So I'll tap the top of the 4th or 3rd cyl manifold for the brake booster. What size tap/fittings/tubing is recommended?
5.) MSPNP first start:
Once everything is hooked up, all I need to do is set Control Algorithm to ITB then start it up (on base 1.6 map with LC-1 wideband selected)? I'd log the data and carefully work my way up at different loads/speeds to edit my itb load switchpoints. I still need to do some heavy reading on the msextra site, but I figure I'd put it out there to get some pointers/direction.
I have many more questions, but I'll let this stew for a bit.
Thanks, and hopefully I can help CR as much as it has helped me!
1.) IAC:
3.) Vacuum block:
4.) Brake Booster:
