21 - 28 of 28 Posts
Aero Master
Discussion Starter #28
no, the chambers are not connected. That would defeat the purpose of the stock designed system. Our catch can has 3 ports on it: 1 is for 1 chamber only, the fresh air chamber, this feeds fresh air to the valve cover, which would normally be connected to your intake pipe; the other 2 ports are for the other chamber, the closed chamber. This goes between the PCV valve on the valve cover and the intake manifold. If both of our chambers were connected and vented to air, you would be causing a large vacuum leak and the car would run very poorly.
-Henry
21 - 28 of 28 Posts
