1 - 20 of 20 Posts
Now in a White Club
Front lip, sans signals and fogs:
Front Lip w/ Fogs:
Signals, Fogs & Lip:
Front lip, of course, is the Mazda OEM piece.
The fog lights are from R*Speed, not sure of brand, as Joe just had them in a little brown box for me. They were very easy to mount, as I used some existing holes that had plastic screw plug things in them, and just took those out, and installed the bolt, and nut on the top side.
The turn signals I got from eBay. Fit & fitment were superb. came with new screws, and new bulbs and harnesses. I didnt use the harness or the bulbs, as I had my own, and my harnesses are hooked up for winky side blinkers (notice the extra bulb in the turn signal)
Looks hot man!! i love the Fog Lights, i need to put a set on mine again, i miss blinding the a-holes with them. And it looks tough too. Keep it up!
Phatty
Lit like a BranchDavidian
fogs = good
I don't know why more people dont get the TSi's though, they're pure sechs
Now in a White Club
Discussion Starter · #13 ·
thanks for the replies & compliments. I originally saw the turn signals on "I Rike Beer"'s car (i think...) I like TSi's too, but I just didn't think they fit the "style" of my car... anyways. thank's again!
I'm really digging those Fogs. Im not really a fan of the low pro fog look, so these slightly larger ones seem to be what im looking for. and the clear lens is perfect for a white miata IMO.
Beautiful car man.
-Jeremy
Now in a White Club
Discussion Starter · #15 ·
Thanks Jeremy. They are bright enough i can use them w/o headlights as well.
::insert m.net comment here: That is very illegal... using foglights as headlights is not recommended....::
I like the fogs.
Question where did you tap in for the power??? I have some fogs I need to mount but just need to figure out the wiring, that whole power source is a biggy
Now in a White Club
Discussion Starter · #18 ·
im a big wiring nerd and actually ran a power wire all the way back from the battery to the switch, then the switch off of a power window wire (just so it only turns on when the car is on) and then the negative to just a ground in the engine bay. theres also a fuse and a relay. you can pick up relay kits at autozone, or wherever for fogs, and they are pretty easy to wire.
Foglights are as necessary to a car's front end as oxygen is to breathing, IMO!
The car looks FANTASTIC.
Now in a White Club
Discussion Starter · #20 ·
thanks man. btw I love your sig, though I always pause to watch it all the way through... haha
1 - 20 of 20 Posts
