1 - 9 of 9 Posts
Whiskey makes me Frisky
I would think the only thing it might do is mess with the valve seats but thats just what the brain is saying on no sleep, but why would you want to and isnt it easier and cheaper to find unleaded!?
Yes but i am wanting to run 110 so i can advance my timeing a wee bit more.. and not have to worry about pinging. Just for the track.
bad mother f......
It will damage your 02 sensor and catalytic converter.
leaded gas of such high octane lowers more performance and more damage than good.
using 100octane straight already causes sputtering and a decrease in acceleration in my fuel injected honda without the proper mixing ratios...how much timing are you expecting to advance?
not all instances where higher octane equals more power.
bad mother f......
no knock sensor on a NA
why don't you just advance enough to run safely on 91 octane since you only wanna advance a wee bit gumby?
just reset the ecu and pump away... but than what do i know. if you get results from using 110 octane and no boost, post up mang.
good luck
1 - 9 of 9 Posts
