I recently purchased a set of trmotosports 15x9+ 36 which rub on both upper and lower control arms on the driver side and on my sway bar on my passenger side at full lock. I am also running a set of i concept tie rods which due indeed give me more angle and is a factor in the rubbing, but prior to running these wheels i had a set of 15x8 +20 and everything was fine. As a result to the new rubbing i went ahead and purchased a 5mm spacer from h&r to see if it would cure the rubbing at full lock. It helped a good amount but i am still rubbing, now have come to a conclusion that A my rack may not be centered, B I need bigger spacers or C my car may have been hit.
If anyone as an idea or a word of advice i would greatly appreciate it, the car is aligned and drives straight I am a bit out of words and would like to go in the right step to fix the problem
