1 - 14 of 14 Posts
What oil weight are you using? There's a thread or two on here that goes in depth on the subject. It's most likely your Hydraulic lifters so the oil should help it. If you have a very high milage car... It may just be there due to the age and wear on the lifters/valves.
Get rid of the 20-50 oil and go back to a good 5-30 or 10-40..seafoam again..it might take a few short oil change intervals before they get clean enough to stop making noise.
the clearances on these things in that area are pretty tight so that thicker oil has a tough time getting in there..making the problem worse..go back to the 5-30 or a 0-30
I agree. I wouldn't take apart the head just yet..
My car does this sometimes on cold days on startup, the oil is cold and thick and can't get in the HLA's thus causing the ticking. You said you put the thickest oil they had, which might be the case why its ticking, as stated before. Try Castrol GTX High Mileage maybe? But lower weight: 5-30ish...
Good luck!
1 - 14 of 14 Posts
