1 - 3 of 3 Posts
Hey guys..
I'm looking to get a lightweight Aluminum Crank Pulley for my 1.6 block, but can't seem to find much available, for the 1.6 at least..
I've came across plenty of lightweight pulleys on the net, but they were all for the 1.8...
Q: Would the 1.8 crank pulley fit on the 1.6 crankshaft? Are the bolt patterns exact?
Thankks
brontosaurus
A: Nope, thank google.
http://forum.miata.net/vb/showthread.php?t=233503
Our dampers are a part of our pulleys anyways. Bad idea to replace with a light weight pulley because they delete the damper. If your engine is relatively stock you can get away with it, but they can grenade motors. Never put one on a FI engine, the vibrations will kill your motor quick. Many miata specific engine failures due to removing the damper. The only safe one to use is the ATP damper.
1 - 3 of 3 Posts
