i just picked up a new set of wheels, D-Force 5 spoke wheels. the holes for the studs are thick enough that the studs don't clear the front of the wheel. Not a big deal in itself, but the hole is small. Small enough that regular lug nuts just fit in the hole and there is no room for a socket to go around it in the hole.
I know a lot of after market wheel are like this now. Those that have a similar issue, what lugs have you found that work well. Extended hex head lugs, or spline drive types? i have a broken stud, so i will be replacing them all anyway, may as well get some extended studs to ease mounting also.
Thanks, Kirt
Thanks, Kirt
