1 - 3 of 3 Posts
im looking to order iConcepts tie rods for my car. BUT! Rod at tetsuyagarage says that theyre specifically for powersteering. anyone know if there is a difference between the "THREADING" on the racks?
for clarification.. can i use powersteering tie rods on a manual rack.
Premium Member
no you cannot, thread pitches are different.
i can sell you a depowered rack done the flyin miata way.
shaft completely lubed and ready for use.
the lines are crimped shut but you'll still need a pressure line blocking bolt and return line blocking bolt.
or you can just buy the miata roadster depower bolt set.
Discussion Starter #3
id much rather keep the actual manual rack. do you have an idea of what the thread pitch on the inner tie rod is for the manual rack?
1 - 3 of 3 Posts
