1 - 15 of 15 Posts
Supporting Vendors
Mazda Miata Interior LED Conversion
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Miata's map lights, license plate lights, vanity lights, trunk light, turn signals, fog lights, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Our LED bulbs will replace the incandescent bulbs in your vehicle for the interior. It has been tested in your Miata (MX-5), for perfect fitment, and no guesswork! No modification is required for installation, you simply replace the bulbs!
The product pictures are professionally taken, at the same camera settings, in order to provide an accurate idea of what the bulbs will look like, in terms of brightness compared to the factory bulbs.
Brightness.We offer several bulb models for different levels of brightness. All bulb models will provide a sharp, modern LED look, and all include the same number of bulbs. Please be sure to read all of the following information:
  • SMF2: Near factory brightness. (16 lumens)
  • SMF4: Slightly brighter than factory. (56 lumens)
  • SMD6: Brighter than factory (56 lumens)(Trunk Option)
  • SMD12: Much brighter than factory. (LED Board / 118 lumens)
  • Flexlight: (Trunk only) This is a flexible LED strip with connector, for plug-and-play installation. It replaces your factory trunk light, and can be positioned anywhere you would like, with included velcro and adhesive.
All brightness levels are for general reference only, and apply only to the use of white LEDs. Please see the note below regarding the use of colored LEDs.
Please note that the SMD6 and SMD12 trunk light is often an LED board, which must be installed directly on top of the trunk light housing to achieve maximum brightness. All other lights will fit inside of the light housing with no modification. Some stage interior lights use direct-replacement adapters with an LED board for maximum brightness.
Color. White is our most popular color. It is a 6000K cool LED white. We also offer yellow, green, blue, and red, at no additional charge. When making your color selections, please bear in mind that white projects the most usable light, so white will appear brighter than the same stage of a colored bulb, usually by one stage difference. For example, a red SMD12 light will have a similar usable light output as a SMF4 white light.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Questions? Send a PM or email [email protected] or call: (314) 205-3033
****We have products for all Miata model years****
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Re: FS: Miata Interior LED Conversion! Map / Footwell / Trunk Locations! Several Options!
do you have these for the top interior light for NB?
WHY YOU NO 91!?
Supporting Vendors
Discussion Starter #7
WHY YOU NO 91!?
We have bulb sizes available for nearly every factory bulb size, if you don't see what you are looking for on the site feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
Just bought a pair of plate lights for my other car (2000 subaru outback) because one was blown out.
Really improved the lighting situation back there, and it gives it a high-end look.
Considering getting more LEDs for my miata! Maybe a map light
Supporting Vendors
Discussion Starter #9
Thanks for your support!
Let us know if you have any questions about lighting for your Miata
Nick C.
Just sent you a email.
1 - 15 of 15 Posts
