1 - 20 of 21 Posts
Supporting Vendors
Mazda Miata MX-5 Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Mazda Miata MX-5 fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your Miata's fog lights a nice bright white (or yellow)!
Plug and play installation, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Bulb Design
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Mazda Miata & Mazda MX5).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2004-2005 Mazda Miata
Diode Dynamics: Fog Light LEDs for 2006-2015 Mazda MX-5 Miata
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Re: FS: Fog Light LED Bulbs! Several Brightness Options! New XML2 Added!
Were the fogs changed for 04-05? I'm assuming these wouldn't work in my 01 fog lights?
Supporting Vendors
Unfortunately, the 2001-2003 Miata uses an H1 sized bulb which is a rather small size. We don't offer the XML2 or XP80 for that bulb model yet.
There isn't enough room for proper heat shrink on the H1/H3/880/881 sized bulbs for the XP/XML2 LED styles
Nick C.
Administrator
Anything for 99-00 fogs?
Re: FS: Miata Fog Light LED Bulbs! Several Bulb Options! New XML2 Added! Plug and Play!
The fogs are $40 for a 2007 and yellow is free but it's only compatible with the lights that are at least $50 extra?
Supporting Vendors
The bulb size is different for each generation of Miata
The older generation uses an H1 bulb, which is considerably smaller than the 9006 & H11 bulb size that the newest generations use.
Unfortunately, the H1 bulb size is too small to fit enough heatsink for higher powered LED options like the XML2 and XP80 we carry.
If you are looking for a yellow H1 bulb model that produces usable output, you'll want to use a quality halogen bulb or 35 watt HID conversion kit
Feel free to give us a call if you have any questions: (314) 205-3033
Thanks!
Nick C.
Supporting Vendors
Re: Mazda MX-5 Miata Fog Light LED Bulbs! Plug & Play Install! Same-Day Shipping!
Customer Submitted photo with Yellow XML2 Installed
Nick C.
Supporting Vendors
Diode Dynamics: NEW! Stage Series Light Bars
Introducing STAGE SERIES LED lighting! Inspired by the needs of a professional rally driver, these light bars have been designed for maximum functionality, with compact size, cutting-edge TIR optics, and a useful beam pattern, all in a highly durable package.
-Advanced TIR (total internal reflection) optic
-Slim design, for easy mounting
-Available in driving or wide beam patterns
Supporting Vendors
Our Stage Series Light bars are available in Amber as well! Here's the Driving and Wide output comparison shots!
Thank you,
Nick C.
Supporting Vendors
Discussion Starter · #13 ·
Don't miss your chance to save on all LED upgrades! Through Monday, 7/6/20, get 15% off all our LED upgrades for your ride, including our Fog Light LED Bulbs with coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.​
Supporting Vendors
Discussion Starter · #14 ·
Our Labor Day sale starts NOW! Today through Tuesday, 9/8/2020, save 15% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "LABOR" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
Supporting Vendors
Discussion Starter · #15 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/8/2020, you can use coupon code "LABOR" at checkout for 15% off your entire order of lighting upgrades, including our Our SLF Fog Lights!!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Supporting Vendors
Discussion Starter · #16 ·
Uprading your factory halogen foglight bulbs to our SLF LED Bulbs can make a HUGE difference when it comes to nighttime visibility!
Don't forget to PM us for free USPS shipping!
-Collin
Diode Dynamics
Supporting Vendors
Discussion Starter · #17 ·
This is NOT a drill! Our Black Friday sale starts NOW! Today through Monday, 11/30/2020, you can use coupon code "BF15" at checkout to save 15% on all LED upgrades, including our Fog Light LED Bulbs.
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 11/30/2020. Cannot be combined with other coupon codes.
Supporting Vendors
Discussion Starter · #18 ·
Don't miss out on our lowest prices of the season! Through Monday, 11/30/2020, get 15% off all our LED upgrades for your ride, including our Fog Light LED Bulbs.
Use code BF15
Collin
Diode Dynamics
Supporting Vendors
Discussion Starter · #20 ·
We recently released a video explaining the differences between lumens, lux, and candela and which of the 3 determine the true output of an automotive LED bulb or lamp. Check it out above!
Also, don't forget to PM us for free standard-economy USPS shipping!
John C.
Diode Dynamics
1 - 20 of 21 Posts
