Hello all. Here is the story.
I was driving on the 405 getting off at harbor. I heard a little sound in the rear of the car like my wheel was out of balance. I just put it to the back of my mind because it stopped.
I pulled over to look up the place I was going on the GPS and then continued to pull out of the parking lot.
As I was pulling out the car sounded like it was scraping (as usual on bumps) so i let the clutch out to move forward and it just would not go.
I put on the flashers and got out. Nothing I can see was wrong. So i got back in and then stared her up. It was just grinding. It would go in to gear but would grind the second the clutch was let out.
I got it towed home and i took the center console out and removed the shiftier. Then put it back in and now the car (why this had a an affect i do not know) will not grind it just wont move.
If I put the car in neutral it will not move like it is in gear or the rear is locked up.
If i push it a little the car makes 1 pop pushing forward and then 2-3 pops coming back. I cannot figure this out!
I made a video and tried to explain as best as I can
Thanks in advance! :littlepony:
