my engine oil is gradually leaking from the bottom...
STFF and found out it's likely front seal... if not, then oil pan gaskets...
bought timing belt kit from rosenthal which included front seal and had local shop do the work...
visited the shop again and they said it's not leaking from front seal for sure and it's likely leaking from oil pan gaskets...
bought oil pan gaskets and had another shop do the install...
but it's still leaking... what else can it be???
