This is the rubber that the side window glides in when going up and down.
I have changed wires, and the regulator but the window still dont run up and down.
When trying try to slide the window up and down it's get stuck in front in the rubber....
Also the regulator runs up and down nice without the window in.
After som investigation if found that the rubber weather-strip is a kind of wavy.
Is this normal and should I continue to search after the issue or is the rubber weather strip worn out and need to be replace?
Edit:Sorry picture number had more focus on my spare parts than the actual object.
