Do the Nakamae M2-1028 style door panels work with manual window lifts? All the pics I see have a cutout for the door lever, two holes for the pull strap, a speaker hole, and optional map pocket. Is it possible to use these panels with manual window lifts or should I just upgrade to power window lifts? How would I go about cutting a hole for the window crank so that I don't cause irrepairable damage to the vinyl upholstery? If I do have to upgrade to power windows now might be the time to do it since my driver side manual window regulator is very stiff when rolling up and in need of eventual replacement. The window is stiff only when rolling up, not when rolling down - I checked and the tracks are clear.
