21 - 24 of 24 Posts
Discussion Starter #22
Thank you!
Car is somewhat at a stand still due to needing to buy a winter beater.
But since my last update I broke the slave autocrossing, replaced that. Installed the Carbotech 1521's, centric premium rotors, goodridge lines, mazda comp mounts, and hella horns.
Next step is most likely Bride's, harnesses and a custom roll bar. Hope to update this more over the winter.
Discussion Starter #23
Geeze, I need to update this.
Did a bunch of track days at the end of the season.
Upgraded to Carbotech XP8 pads, swapped the KoyoRad for a mishimoto after the koyo failed and leaked(nothing against Koyo), ordered Garagestar Delrin Bushings and Seat rails, Sabelt GT090's and Sabelt Harnesses, Racing beat header which is at swain tech for coating, port matching my intake manifold for the throttle body and turning my harddog hoop into a 4 point rollbar. May also end up doing some testing on some PMU Club Racer pads and rotors, but that is still up in the air. Also, depending how my times look and how much I progress this year I'd love to switch to a dedicated tire and wheel setup at some point. Car should be back on the road by may so I will update the thread then.
21 - 24 of 24 Posts
