Hey guys got an issue with the Nopro NB. I'm running the Jackson S/C system on the car, up until recently it has been great. About 1000 miles ago I started to notice that whenI am on full boost in 3rd, 4th, and 5th gear the motor started to spit and spudder and sound like ****. W-T-F. I'm running the split fire direct fire ignition, that was suppose to be the best thing since choclate ice cream for the 99's, well better than the factory coil packs I should say. Also had Ngk irdium plugs. The car barley has 93000 miles on it. I don't hammer this car! It's my show car. I changed the plugs on Saturday. After seeing the old plugs it looks as if the motor is running lean more of the time than rich. So after the plug change went and drove it, still the same thing. What the hell. Could it possibly be something with the mass air sensor or what???? :?: I'm looking for anything here guys. Other than shell out the money for a piggy-back link, what can I do???? Hector @ Rspeed has done all the work on the car, so it is'nt an error on my part I don't think. Sorry for the long post, but it is bugging the hell out of me. Thanks, and hope to hear from ya'll soon, Caleb(frosty115) :?:
That's very bizarre that it wouldn't trip any fault codes at all. Well, it can only be 1 of two things: fuel or spark. I don't have a 1999 Factory Workshop Manual in front of me but I do have a 2001 FWM. It has an entire 150+ page section devoted to engine control system troubleshooting.
Engine runs rough/rolling idle:
Improper engine compression
Improper valve timing
Fuel quality
Engine overheating
Air leakage from intake-air system (Loose tubes, cracks, gasket breakage)
IAC valve improper operation
Variable valve timing system malfunction (again, I'm loooking @ '01 manual so may not apply)
Vacuum leakage (Vacuum hose damage, misrouting)
Initial ignition timing misadjustment (CKP sensor and crankshaft pulley misalignment)
Spark plug malfunction (e.g. open, short, cracks)
High-tension leads malfunction (Cracks, open, low resistance)
CKP sensor is damaged (e.g. open or short circuits)
Crank shaft pulley is damaged
Improper gap between CKP sensor and crankshaft pulley
FP malfunction (mechanical or electrical)
Pressure regulator malfunction
Fuel hoses restriction or clogging
Injectors malfunction (Leakage or clogging, inoperative)
Fuel filters restriction or clogging
CMP sensor is damaged (e.g. open or short circuit)
Crankshaft is damaged
Improper air/fuel mixture ratio control
Exhaust system restriction or clogging
EGR system malfunction
EVAP control system malfunction
PCV valve malfunction
TR switch misadjustment
PSP switch and related malfunction
Improper refrigerant amount malfunction
Condenser fan system malfunction
Improper load signal input
Engine runs rough (acceleration/cruise)
Misses (acceleration/cruise)
Ignition coil malfunction (e.g. open, short, cracks)
Buck/jerk (acceleration/cruise)
No possible factor provided in symptom quick diagnostic chart
Hesitation/stumble (acceleration/cruise)
MAF sensor and related circuit malfunction
Surges (acceleration/cruise)
As you can see there are a lot of things you can check. Time to start hooking up your scan tool to monitor sensor outputs when the event occurs.
Haha. Yeah, driveability issues are tough especially if you have no fault codes to steer you in the right direction. All that stuff I typed up above was from the easy fix section of the service manual. The other 148 pages deal with the complicated troubleshooting stuff.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
