21 - 23 of 23 Posts
Sounds like it, the ground is ESSENTIAL. Where ever you are trying to use as a ground make sure it is bare metal, paint can/will prevent it from grounding properly.
Discussion Starter #22
I have tried 6 different grounds from the trunk to the hood area no fucking luck. Any other thoughts?
Administrator
Let me make sure i'm on the same page with the following statements:
1) Your stock lights still work as designed. Brake/running/turn signal/reverse
2) The Porter lights work if you power each individual section power/ground to battery
Are both these statements correct?
If so, then you're hooking something up wrong. No way around it.
21 - 23 of 23 Posts
