KazeSpec Engineering is now an HPS Silicone Hoses dealer!
Details
The Mazda 90-05 Miata HPS High Temp Reinforced Silicone Radiator Hose Kit is designed to replace stock OEM rubber hoses which can eventually weaken over time, leading to premature failure. With premium quality silicone and race inspired design, this HPS silicon radiator hose kit can withstand the harsh high temperature and high pressure operating conditions of the engine yet still maintaining peak efficiency during competition or daily driving.
Key Features
Stay Cool - Old cracked or split radiator hoses are not efficiently cooling your engine which can cause it to overheat leaving you stranded. So maintain your Miata cooling system by replacing your old brittle hoses now before it's too late. Perfect for racing or daily driving application.
Direct Fit - HPS silicone radiator hose kit has all the correct bends and curves for a perfect fit replacement on your Miata, it is not a cheap one size fits all universal hose you get at the local parts store that you have to fight with to install.
Premium Quality - HPS Silicon coolant hose kit is made from multi-ply premium grade silicone and reinforced with high-quality polyester for which reduces the risk of component failure and enables higher temperature and pressure to be maintained with complete confidence.
Technical Specifications
Temperature Range:- 65 deg. F to + 350 deg. F (177 deg. C)
Color: Black
Material: 3-Ply Reinforced High Temp Silicone (Other brands only use 2-Ply)
100% Stainless Steel Clamps are included for easy installation
Available in the follow colors:
Black
Blue
Red
90-97 Kits are $115+shipping, 99-05 kits are $135+shipping. Get yours today!
Pics courtesy of epileptic
Details
Key Features
Color: Black
Black
Blue
Red
