1 - 7 of 7 Posts
so, recently while driving, i have noticed an odd "clunk clunk clunk" whenever im chugging along in traffic in first gear at super slow speed, almost as if there is play in something down there.
this also happens sometimes as i shift gear, whenever i let out the clutch pedal after shifting, i get a quick clink sound
or when i push in the clutch pedal while decelerating to park or coming into and lot
what do you think this is? driveshaft play? my axles? some sort of bearing thing?
any help would be appreciated
Ditto on drive shaft u joint. Fronts tend to go first for some reason. Are you leaking trans floid or smelling it ? if so check the rear trans seal also,
Discussion Starter #5
no leaks or smells... i always check for those when im under my car
i will check out the u-joints this weekend, if they are bad, can the u joints be swapped? or am i looking at a new driveshaft assembly
Somewhat sounds like the same problem I had... Thought it was the u joint as well but ended up being lose lug nuts lol. I tighten them up and the noise was gone.
Sent from my PC36100 using Tapatalk
1 - 7 of 7 Posts
