1 - 14 of 14 Posts
Esteemed Member
My miata is leaking oil from behind the back of the head and around where the tranny mounts to the motor, the clutch was replaced about 5k miles ago just before I got it, do you think its my rear main seal or my head gasket??
I have the same problem.....got to give it a try
Try it again? Perhaps you damaged the o-ring or it isn't seated properly.
Did you replace your valve cover gasket at the same time?
Did you use a gasket sealant at all of the corners of the gasket? I believe there's like 6 places you're supposed to put a dab of gasket sealant.
Yes, it's likely they'll have it, but I would try your local hardware store first. The problem with most auto parts stores is the way they're trained to help you. First they ask for your make/model/model year and if the answer doesn't pop right up on their computer screen they'll tell you they can't help you. The computer systems they use often have poor cross-referencing capability so you can't just ask them for an 1/8? ? 1 ½? x 1 3/4? o-ring because they'll look at you cross-eyed and ask you again for the make/model/model year. At least if you go to the hardware store you can go to the plumbing section and find the right o-ring yourself.
Esteemed Member
Yup. Did all that at the same time.
I have a bunch of gaskets and seals laying around and I have found a bunch of o rings in a little plastic bag.
freedomgli: the o ring i have found is a 1 3/4" ring and is pretty thick. Is that the o ring?
I dont think i have an o ring on the CAS in the first place. Unless it is this black thing that is hard as a rock. If it is how do I get it out?
1 - 14 of 14 Posts
