1 - 15 of 15 Posts
Speed Tribe OG Member
Hey guys, just wondering if all oil pumps are created equal? Also what are the best alternatives to OEM?
Thanks in advanced
I read "Boundary Engineering" over at MT.net all the time regarding oil pump gears. Either that, or shimming the stock oil pump.
brontosaurus
I'd go boundary personally. You can hit them up with your engine specs and goals and they'll point you to the right one.
http://boundaryengineering.com/drupal/node/7
Toda also makes stronger gears, but at $50 just for gears they are much more expensive. From boundary you can get the full on race high flow pump for ~550
Thanks for the link, I think I will go with them. I like the entire package. Especially when an oem pump is $400
Discussion Starter · #5 ·
Did some research on the boundary pumps, found out they are having issues with their pumps failing. Also was told by another member, that they start with the china made housings and just hone them out. But then have quality and fitment issues. Can anyone deny or confirm this?
MT.net, CR does not do much for information.
I've heard that to. When I was looking for one for my boost build I decided to to with an oem nb8b. They have slightly larger gears and unless ur revving above 7500 that's more then enough. They are $250 brand new from Bill at Miata Roadster
I've read about shimming the oil pump. Exactly how much, I don't know, don't want to misdirect you.
never had any problems with BE oil pump. Never, never, zero nada but the Adaptronic piece of **** computer that I got from Travis never work and getting in contact with him was a mission plus it took me over a month to get mine.
yeah thats what Boundary does to increase PSI.
Ive always wondered why factory supposedly has a limitation of 60psi warm (there is a relief valve supposedly). 60 psi on my other car might be considered low... but maybe it has to do with engine clearances?
1 - 15 of 15 Posts
