2921 - 2930 of 2930 Posts
Discussion Starter #2,921
Re: Oregonmon's white 1990 - I did it for the gram
Sup fam. Updated that build log today, so dusty.
1990 B package
Engine/Exhaust
-2002 1.8 VVT engine, rebuilt August 2014, mild head shave 10.2:1 compression
-Engine dyno'd before supercharger 3/26/15 137hp and 121ft/lbs torque (near peak torque at 2400rpms)
-bottom end rebuild summer of 2017
-Forged K1 rods
-ACL race bearings
-polished crank
-stock pistons
-new Mazda OEM oil pump
-Setrab oil cooler, mounted at steering rack
-Mtuned coolant reroute and custom reroute hose
-AEM oil temp gauge with sender at oil drain plug
-AEM AFR gauge
-Racing Beat header 94-97
-Enthuza 2.5” test pipe or Enthuza metal core cat
-Racing Beat non resonated mid-pipe
-Racing Beat Power Pulse muffler
-Rotrex C30-74 supercharger with 75mm pulley (dyno'd 245hp/195tq)
-ebay bar and plate intercooler with custom charge pipes
-Kraftwerks rotrex oil cooler and resevoir
-Turbosmart BOV
-K&N Intake
-MSLabs built Megasquirt 3 Basic
-Mazda Competition motor mount/V8R billet mount hybrid
-Skunk2 64mm body
-Skunk2 Intake manifold with upgraded billet throttle cable bracket
-CX Racing aluminum radiator
-powdercoat black valve cover
Suspension/Chassis/Drivetrain
-Motion Control Suspension (MCS) single adjustable monotube dampers
-Eibach 2.25” springs 6” 700lbs/in front 7” 400lbs/in rear
-alignment numbers- front camber -3.1 rear, 2.7 degrees, toe -.08", caster 3.8'
-corner balanced 10/2018
-OEM NB top hats
-1994 power steering
-Racing Beat hollow front sway bar
-Superpro poly steering rack bushings
-Curly Shade Tree Garage aluminum steering rack spacers
-R package tie rod ends
-Thompson Automotive front control arm brace
-4.3 Torsen swap with Energy Supension Poly differential mounts
-949 Racing 7.8 Aluminum 1.6 flywheel
-Supermiata 1.6 Hybrid Organic clutch
-Trackspeed Engineering stainless clutch line
-1999 6 speed tranny with 50k miles as of 11/2018
-IRP Short Shifter
Wheels/Tires
-TRM C3M 15x9 +36 offset wheels
-225/45/15 BFG Rival S
Brakes
-V8R Stoptech 11.75” ST42 front brakes with Wilwood discs
-new Miata Sport rear callipers and Stoptech slotted discs
-Stoptech Sport pads all around or PFC front pads for track
-Stainless braided lines
-ATE DOT 4 fluid
-Wilwood 1” Master Cylinder
-Wilwood proportioning valve
Safety
-HardDog Hardcore M2 Rollbar
-Sonic Motors VS3 driver seat
-Sonic Motors P2 passenger seat
-PCI V1 seat mounts
-Schroth Profi 6pt. camlock harness (driver)
-NRG quick release
-Works Bell steering wheel hub
-Momo Monte Carlo suede steering wheel
Interior
-DIY door panels, faux suede, RS style door pulls
-LED bulbs
-Tablet connected to Megasquirt via bluetooth, running MSdroid
-Tablet also connected to audio amp via bluetooth for streaming music, google maps, etc..
-Kenwood 4 channel amp (hidden)
-Clarion 7 band EQ installed in glovebox
-Rockford Fosgate Punch 6.5"/1" separate component speakers
-radio delete plate, switches for MS controlled lauch control, audio amplifier power
-Billet pedals
-center console delete
Body/Cosmetics
-Snugtop hardtop
-Garage Vary rep front lip
-Garage Vary canards
-Front and rear tow hooks
-Garagestar black radiator panel
-Rspeed hood struts
-All turn signal, side marker and license plate bulbs to LED
-Osram Night Breaker in H4 headlight housings
-Rear bumper cut and bumper support delete
-APR carbon fiber mirrors and adapter plates
-antennae delete
-APR GTC 200 48” SCCA version with standard height stands
-Blackbird Fabworx adjustable lexan spoiler mounted on 2nd trunk
Discussion Starter #2,923
Celebrating 8 years of ownership next month.
Annnndddd... the NEW addition. 2018 718 Cayman GTS with manual.
follow my instagram @oregonmon i post there much more regularly.
Still never actually said if the Miata is sticking around or that was a vague way to say it wasn't..:suicide: Either way congrats again on the Porsche! You have taken the Miata so far and 8 yrs! Don't sell! :smile1:
Premium Member
I know what you mean about driving in the snow with studs. I cut trail across the mountain to work many times and blew everyone away by doing so. 100 lbs. of salt in the trunk and away we go!!!
