After installation of the Greddy kit my car would start to overheat after long drives involving stop and go. Not to mention in 90+ degree weather. I've so far changed the cap, thermosensor, and did a flush. Also made a undertray to help flow. The car also came with a no-name aluminun radiator.
A conclusion that i came up with besides a bad water pump is my starion intercooler is blocking airflow to my radiator which also has the AC condensor infront of it. Im thinking of ripping out the AC units since I dont use it and its been vacuumed out.
I wanted to run a slim fan to replace the OEM unit but wanted to hear experiences from you guys with aftermarket fans. Are you guys running a push or pull fan? Also, what size will I go with?
Below are links that i've found to some great deals:
http://honda-tech.com/zerothread/1461419
http://honda-tech.com/zerothread/1180287
