1 - 7 of 7 Posts
ok so i bought a 1.6 thermostat housing, plugged the sensor on but the fans don't run and the car is still overheating. can i get a list of possibilities of problems that may be causing my car to overheat? needle still hits H..
Discussion Starter · #5 ·
lol i wish i could bring the car to you.
anyways i'll check the fuses in the engine bay.
and for the ground for the sensors, can i get a picture of your engine bay?
or can you point out the sensors that needs to be grounded.
btw im still using the 1.8 oil pressure sender if that has do with my problem.
thanks Noah!! Will help me out too bro ahah
Check the fan relay if the fuses don't fix it.
Don't let your engine get too hot, it's much cheaper to pull over and grab a drink while your car cools down than to push on home.
where is it located at? the fan relay/all of the fuses/switches/relays that control the radiator fan unit. somethings wrong with my car.. aiyah.
1 - 7 of 7 Posts
