Translation for archive purposes in case file no longer works:
P.125
right column
1 open side tip by minus driver, phillips screw driver, dont broke tips
2 to open the cover, 4 tips were unlocked. then you can see SW trigger
3 put out sw trigger by screw driver, you need more strong work, it's sticking hard.
4 SW trigger is soft, so you may not broke them. remove circuit board from case
5 unscrew 3 screws on case
6 cut the zip tie
7 now you can take out the pcb from the case
8 undo this work again to the other sw case, you need 2 same PCB
column 2
1 remove passenger sw on main pcb, and remove driver sw on sub pcb
2 remove white base of sw which you took out on pcb, using nipper
3 cutting circuit on pcb by small knife
4 front side of pcb. move away/move away/scrape off copper print from board 3 circuit line pointed by arrow
5 back side of pcb. isolate/cut out from circuit 2 pointed area from circuit line
column 3
Note: the following work is done on main pcb (removed passenger side SW is main)
1/2 remove solder and drill hole to fit the sw / clean the hole of open wider the hole
(col. 3 pics 2 and 3 there is soldering of 2nd driver switch onto main PCB)
3 apply white base parts of driver's side sw (remove from sub pcb) to main pcb/solder driver sw on main pcb with correct base / note: 2 white bases are different
4 sub PCB (removed driver sw) (if you want, you can remove passenger sw on sub pcb, it's no use. ) remove wires on 2 arrows and solder wires to points where the driver sw was soldered
column 4
1/2 solder wires from sub pcb to main pcb passenger position/red(power) on sub to red on main /black on sub to black on main/sub red/white to red/blue on main
3 make hole in case for wires from sub pcb
4 put main pcb into case and attach buttons
5 wrap the sub pcb by vinyl tape to avoid trouble
6 here is enough room beneath center console for sticking sub pcb
bottom
NA6 owner needs more wire. early na6 doesn't have auto sw even only driver's side, so the length of the wire is not enough. simply cut the original wire and add the wire to same color.
"FC switch is looks cool in red letter and assumed to fit in the shape, but doesn't match to Roadster absolutely"
Thanks to whoever actually performed the translation and thanks to Bill the pics.
