81 - 100 of 128 Posts
Beeeeer!
Ok... so here comes the noob question. I see headers ending in 2" or 2.25", yet exhausts like ebay specials are 2.5". Is everyone running some sort of expansion test pipe?
Any special type wire connectors, or did you solder them
I used butt connectors, no solder. Can't remember if I put dielectric grease or not, but I definitely taped over the entire connector to make sure it sealed up nicely.
They must have removed it from their site....because theres one attached to my motor right now lol
on the m.net thread someone contacted raceland and they said 1.8 headers will be back in stock may 26th but thats the only reason you cant find it is because they dont have any.
I was thinking about getting these, the only problem I have is that it deletes the cat and I'd prefer to keep mine
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Quote taken directly from their website
"This 4-2-1 exhaust header achieves this better flow by increasing the size of the header piping and removing the power-robbing catalytic converter."
Maybe they're generalizing for OBDII California NBs or something with the pre-cats (correct?), I can't say for sure. No matter, you have a '95 and I have a '94, both OBD1 with one catalytic convertor so our applications match. The Raceland header will mate right to your catalytic converter, not replace it.
Check mine out installed: http://clubroadster.net/vb_forum/1295714-post57.html
The flange you see at the rear is to bolt to your cat.
Ahh ok, sick! Thank you good sir
