1 - 9 of 9 Posts
So when i installed my racelands, i tried to put the rears all the way down, but had to put them about an inch up because the collars on the strut hit the axle. Obviously this is not a problem that only I had so what do i do to go lower without worrying about this? Going to order ISC top hats very soon also.
The top hats will fix the problem because you can then raise the collars up. For now you can either dremel the collars a bit or just live with the suspension a little higher until your top hats arrive.
<10 posts should be forced to search before they can create a new thread. Seriously.
Way to go guys... kept the thread alive long enough for him to get enough responses that he doesn't have to search anymore! :x
"How to correctly install Racelands" should be a stickied requirement for new members to read.
1 - 9 of 9 Posts
