Does anyone have solid information on removing the abs system from there NA? Is it as simple as just rerouting the lines and removing the computer?
Thanks for any help.
Why?I went through a lot of trouble to retrofit ABS in my car which probably tells you how important it is.
My recommendation is to keep it and if you don't want to use it pull the fuse, it's a HUGE AMOUNT OF WORK to convert a car from one configuration to another (the sold brake lines under the car need to be swapped).
So was this correct?So basically get a new master cylinder for a non abs miata and a proportioning valve and brake lines. Install, bleed, done.
Well my case was slightly different. I ended up buying the car with the ABS and I wanted to do a clean swap and have both cars running with functional brake systems.Why?
All i did was cut it in the engine bay below the frame rail and use one of those union fittings to make them work .
Oh i got ya the brake lines aren't that hard to deal with when removing things but when adding it yeah it would be a pain in the ass . I left my harness intact in case i sell the car and the new owner would want to run abs . I don't recall any difference in the A-arms i think if i was swapping it from one car to another again i would just pull the knuckle with all arms attached to make it easier . The bolts holding the sensors snapped on both my fronts and i haven't touched the rear sensors .Well my case was slightly different. I ended up buying the car with the ABS and I wanted to do a clean swap and have both cars running with functional brake systems.
Swapping the lines wasn't the most difficult thing. Removing harness from the corners and cavities of the body, identifying and fishing out the correct wires was the biggest headache (my fingers and nails still hurt). To do it right you also need to swap the upper A arms which wasn't a big deal since the new vehicle needed bushings anyways.
