I purchased this car about a year ago with the intention to build it for Spec Miata Racing, but the car is to nice to trash it.
Unfortunatly I decised that after I started rebuilt the engine.
This will be one of the only NA Miata with a better than new engine you’ll ever find, it was built with no expenses spared.
It is a completely new engine build from the bottom to the top. Most important It has had a 2003 Big Bore Crank Upgrade !!! (Ill be happy to explain)
The only original engine parts are the Rods and Block ALL the rest are brand new from Mazda
I have broken in the engine for 1000 miles, rebuild was at 143,000 miles. I just did a four hour road trip and it was great.
It also has a Limited slip diff, steel braided brake and clutch lines, Silicone hoses
A/C is freezing, new front brakes, ACT performance clutch opened cat
It has Royal Purple in now after break-in runs stronger than any 1990 you’ll ever drive. I have removed the factory steering wheel and airbag and replaced
with hub and sport wheel. So of course air bag light is on Tops in great condition Paint is shiny and flawless.
The bad
Stereo works but not great
Cruise control is inop I noticed on trip, will be looking into
This is a link to my build pictures. http://picasaweb.google.com/4theinz/Miata?feat=directlink
I was concerering parting out to recover expenses but would rather sell as hole $6500 obo
This is a copy of my parts list that does not included shipping or labor
Source Part Number Description Quantity Unit Price Extended Price
Ferman Mazda B3C7-11-400 Boss Pulley 1 $60.62 $60.62
Ferman Mazda B3C7-11-317 Woodruff Key 1 $3.37 $3.37
Ferman Mazda 8DN1-10271 Gasket Set 1 $210.22 $210.22
Ferman Mazda B6S7-11-300A Large Nose Crank 1 $473.97 $473.97
Ferman Mazda B3C7-11-321 Pulley Tab 1 $22.77 $22.77
Ferman Mazda B6S8-11-401 Pulley Crank 1 $111.20 $111.20
Ferman Mazda BJ01-12-113 Valve Seat 8 $4.00 $32.00
Ferman Mazda B6BF-12-113 Valve Seat 8 $5.84 $46.72
Ferman Mazda 9YA0-20-609 Bolt 11 $2.63 $28.93
Mazda B660-12-700F TENSIONER 1 $50.91 $50.91
Mazda B600-12-711C Spring Tesioner 1 $2.38 $2.38
Mazda B660-12-730C Idler 1 $45.33 $45.33
Mazda B6S7-12-205 Timing Belt 1 $36.56 $36.56
Mazda B672-11-SA0C Piston 4 $46.41 $185.64
Mazda B6Y4-11-SC0B Ring Set, Piston 1 $138.67 $138.67
Mazda B6Y0-11SE0 Metel Set, Conn 4 $45.01 $180.04
Mazda B6Y3-11-SG0 Metel Set, Main 4 $71.93 $287.72
Mazda F801-11-303 Ball Bearing 1 $9.80 $9.80
Mazda B661-14-100 Oil Pump 1 $215.75 $215.75
Mazda B660-15-010r-ME Water Pump 1 $72.36 $72.36
Mazda B6Y3-11-SJ0 Metel Set, Thrust 1 $24.14 $24.14
Mazda H001-64-493 Silent Pack 2 $2.60 $5.20
Mazda FB01-64-481B Pad 2 $1.36 $2.72
Mazda NA01-64-481B Insulator 1 $2.72 $2.72
Mazda M513-17-480A Dust Boots 1 $17.56 $17.56
Mazda 0000-02-9402 Shifting Bushing 1 $9.35 $9.35
Mazda NAY1-39-040 Eng Mounts 2 $86.45 $86.45
Mazda B660-10-135A Head Bolts 10 $8.31 $83.10
Mazda ZJ01-10-138 Head Bolts Washers 10 $1.29 $12.90
Engine Lab Recon Cyl Head 1 $297.00 $297.00
Engine Lab Shop Supplies 1 $62.87 $62.87
Engine Lab Clean/Inspect Main Caps 1 $189.00 $189.00
Engine Lab Clean Tin 1 $112.50 $112.50
Engine Lab Bore & Hone 1 $146.00 $146.00
Engine Lab Sleeve 4 Cyl Block 1 $270.00 $270.00
Engine Lab Cyl Sleeves 4 $51.76 $207.04
Engine Lab Resurface Flywheel 1 $55.80 $55.80
Engine Lab Shop Supplies 1 $5.36 $5.36
Engine Lab Pilot Bearing 1 $17.90 $17.90
Summitt Racing RPO-01335 Royal Purple Assbly 2 $15.25 $30.50
Summitt Racing RPO-11487 Royal Purple Oil 4 $7.15 $28.60
Summitt Racing ETP-E3-48 E3 Sprk Plugs 4 $5.99 $23.96
Pep Boys Shop Supplies 1 $35.81 $35.81
Napa Shop Supplies 1 $25.02 $25.02
Good-Win Racing 61-0407 Gates Racing Timing Belt 1 $59.00 $59.00
Good-Win Racing 15-1015 Braided Stainless Clutch Line 1 $29.95 $29.95
Good-Win Racing 61-0400 O2 sensor Plug 1 $5.00 $5.00
Good-Win Racing 13-1083 Braided Stainless Brake Lines 1 $137.00 $137.00
Good-Win Racing 10-1005 Silicone Vacuum Hose Kit Red 1 $78.00 $78.00
5X Racing 1832880 Silicone Radiator Hose Kit 1 $75.00 $75.00
5X Racing 1827184 Magmecor 10mm Racing Wires 1 $95.00 $95.00
Race-Mart ZM1-HDMM Act Cluch K 1 $310.52 $310.52
Ferman Mazda 0810-14-171B Gasket 1 $1.57 $1.57
Ferman Mazda 9979-40-620 Pulley Bolts 3 $1.24 $3.72
Ferman Mazda B630-10-306 Pin 2 $1.90 $3.80
Ferman Mazda B3C7-11-406 Lock C Bolt 1 $9.16 $9.16
Advanced Auto Shop Supplies 1 $22.45 $22.45
National Cyl Head Lifters 16 $13.29 $212.64
Ferman Mazda 9954-10-3801 O-Ring 1 $4.42 $4.42
Ferman Mazda B3C7-11-408 Pulley Plate 1 $4.43 $4.43
Ferman Mazda B61P-15-106A O-Ring 1 $2.43 $2.43
Ferman Mazda 8AK1-15-171-9U Thermostat 1 $14.63 $14.63
Ferman Mazda N350-18-840 Water Sensor 1 $27.97 $27.97
Ferman Mazda H005-49-470 Seal Kit 1 $6.74 $6.74
Ferman Mazda 9930-71-000 Bling Plug Oil Pump 1 $7.73 $7.73
Ferman Mazda 9954-10-0907 O-Ring 1 $2.84 $2.84
AmsOil Synthetic Dot 3 Brake fluid 5 $6.40 $32.00
Ferman Mazda BP05-13-890 PCV Valve 1 $16.40 $16.40
Ferman Mazda E301-13-338A Seal 1 $2.85 $2.85
Ferman Mazda B621-15-173 Thermostat Gasket 1 $2.96 $2.96
Advanced Auto 33454 Filter Dyer 1 $44.99 $44.99
Advanced Auto 26754 O-Ring Gasket Set A/C 1 $12.89 $12.89
Advanced Auto Shop Supplies 1 $4.37 $4.37
Napa Shop Supplies 1 $38.30 $38.30
Total Parts $5,163.40
The bad
