1 - 11 of 11 Posts
my car has been smoking for a while and got gradually worse. When I crank it after it sits for about 6 hours it smokes up the who neighborhood. It is an assload of white smoke. There is no water in the oil. I goes away after it gets to normal temps, but overheats sometimes. I am loosing antifreeze though. Can anyone give me some suggestions?
bad mother f......
I'm almost certain You have a bad head or head gasket. Your car is burning coolant. How many miles?
for a cheap fix you could just try pulling the head and replacing the gasket, but If you have high milage I thing the best thing to do is rebuild or replace the engine.
Your overheating will continue to get worse, Compression could make its way into the cooling system (If it has not already) and brake your radiator, heater core, hoses, etc.
Discussion Starter #3
the motor has 144k on it, but i rebuilt the head in sept. Could a thermostat be causing it to smoke and overheat? The intake gasket etc? My compression is good too.
double check your ompression.my old motor did smoke up my block bad,had bad valve seals,oil would come out the tip of the exhaust.t got worse ans worse.but i bought it with the bad motor.did my body work first .doing burnouts makes it age quickly.
Discussion Starter #6
im guessing whoever rebuilt the head fucked up putting it back on, pull it off and get it resurfaced and then do a new headgasket.
lol I put it on.
I got all new **** in the head. I guess I could tear it down again. =( What is something I can check before i do tear it down.
+1 Vote for:
Assload of White Smoke = Failed Head Gasket.
You had mentioned you were loosing coolant...
Or maybe a ninja threw a few of his escape-smoker-pellets in your exhaust...
Seriously though, don't run the car at all like that...The whole block is probably screwed from heat, (ALUMINUM) or is on its way to getting hydrolocked by now....liquids lack the ability to be compressed.
Good luck, I sincerely hope you can recover this one.
Ok just to cover all you bases go out and retorque your head. If you can get one bolt to move a fraction of an inch thats your prob. Same thing happened to me last may. Oh, and when you do a compression test be sure to ground out all you spark plugs. I learned that the hard way and it cost me about $100 to replace the coil that I blew.
Discussion Starter #9
/\ I'll try that. This morning i started it and smoke was seeping through were the header pipes meet as one. I'll try the head bolts. I also ordered a new intake gasket and bolts too. Could it possibly be exhaust?
Discussion Starter #10
*UPDATE* the head bolts were torqued down right. I'll check the intake manifold tomorrow. I think I've decided to get a new motor/tranny.
What are some good motor retailers? Are the JDM engines any good?
My '93 smokes at start-up, but its oil smoke.
Are you sure its white smoke like vapor white.
Mine is valve seals, so I'm putting a 1.8 in it next week.
I use a JDM engine guy here in Dallas for my replacement engines.
PM if you need more info.
1 - 11 of 11 Posts
