Okay, I've had this problem for almost 3 years and it's time to solve it.
Here's my current setup:
1993 Manual Vehicle with 1999 Engine + 2001 pistons (running under OBD-I).
My problem:
Engine hesitates (almost wants to stall, goes at 300rpm and then comes back idling correctly) when I press the clutch pedal.
Symptoms:
-It happens mostly when the engine is cold, but also, sometimes later when it's warmed up.
-It looks like it's even worse when I press the brake pedal (could it be electrical-related?, brake light?)
-When I start the car, put it in reverse and then go backward, press clutch (and most of the time, wants to stall right here).
-If I press the gas pedal right before it's about to stall, it usually go idling fine
-I also found out that if I put the air (fans), this problem will not happen because RPM will be higher
-I *think* that when the temperature is cold it's less likely to happen than when it's humid and/or hot
Video:
Not yet...
Reward:
$75 REV9 gift card and many kind words.
Help me help ya!
:hello kitty:
My problem:
Symptoms:
Video:
Not yet...
Reward:
Help me help ya!
:hello kitty:
