1 - 8 of 8 Posts
I just tell myself that my coolant temp sensor is wrong......
ever since I first installed a racing beat header (before I went turbo) the gauge has read between dead center (like it did stock), and a bit to the right of center. I was worried at first, but I drove a summer with the header and no problems. mand then a summer with the turbo and no problems.....
Still, I have upgraded to a KOYO all aluminum race rad, 160* thermostat, and I have an AWR shroud and fans on the way through Bill's group buy. I have also removed the AC condensor from in font of the radiator for better flow.....
All that and stil no significant change in the way the needle acts..... I chalk it up to ambient heat
Finger lickin' good...
I'm working on a radiator sprayer for the even hotter than Hell months we have in FL for both my vehicles.
Aluminum radiator, no AC condenser, 2 10" slim-fans (1240 cfm each) that are always on.
Airbrush,
My NB's temp sensor reads exactly the same way. I also have a racing beat header. But I can't remember if it has always done this or just in the past year in a half after I bought the headers. It scares me a little too. Especially after seeing this picture that shows us reading at about 220 to 240 degrees.
Also you won't see significant changes from your mods since the stock gauge is an idiot temp gauge as described hear. http://forum.miata.net/vb/showthread.php?t=222891
yes, I know it's an idiot gauge..... that's why i'm a bit freaked out about it.....
So far I have added the FM twin cooler, 160 stat, spal fan replacing stock A/C fan (fans run parallel), blocked off front, and removed A/C. Did great for driving, but still overheated on the track.
While the motor is out, I am going to do the coolant reroute. The front will be blocked off completely, bringing the coolant out the rear of the head to the radiator on the passenger side. The heater core return will be ran directly EGI sells.
And I am putting A/C back in. LOL.
1 - 8 of 8 Posts
