1 - 6 of 6 Posts
Sorry for this question, but what exactly is "offset" and what determines it? Would a very large offset make a wheel incompatible with the miata?
Offset refers to how far the wheel mounting surface is from the center line of the wheel (+0). Negitive is towards the inside of the wheel and positive is towards the ouside of the wheel.
ah ok i thought so... so technically if you had like +20238408, the wheel would be incompatible because the wheen would start to rub up against the control brace or someting
if that is true, what are the offset limits of a NA miata
and what bolt pattern does the NA use? I searched through the forums, and used the search button but couldnt find what i was looking for
1 - 6 of 6 Posts
