Hello all!
I own a 1991 NA6, and I'm experiencing some sort of clicking/ticking sound in which I cannot locate/diagnose exactly; I figured it be the timing belt however when I took everything apart I found that the current belt couldn't have been more than a few thousand miles old (from the PO) and that the timing was spot on (After ordering a Continental Contitech timing belt complete with the idler, pulley and belt itself). It could be from me running such a heavy oil 20-40 Valvoline**. My oil lifters are basically communicating with me via clicking saying "Screw you for over-working us" XD I'll do an oil change as soon as possible and pray that it will fix the problem!
I was dismayed, however, to find all the gaskets/seals to the belt dust covers were all sloppily installed and they're all stretched and deformed to the point I cannot salvage a single one. I'm going to order/replace the seals this weekend, time willing through my shop. I'm also having a problem getting into 1st and reverse. I checked the master clutch cylinder to find it almost dry so I filled it nearly to the brim with some DOT 3 brake fluid, and the transmission felt better than new! Sadly, I started to experience the stubborn 1st and reverse getting stuck again with the master cylinder full; my verdict could be either the clutch cable or slave. I'm going to lubricate the bottom section of the shifter with some gear oil and see if that does me any good.
**Before anyone goes about calling me crazy for running such a thick oil I have a reason:
The PO had did an oilchange the week of me picking up the car using Royal Purple which does more sheering than it does lubricating so the cylinder ran a little hot thus NOx) I replaced oil with something thicker and I passed with flying colors. Being a 91 it had to run the dyno and to my surprise no one at my local Jiffy Lube knew how to drive stickshift... and they weren't very friendly... I ended up having to run the dyno myself; it was pretty cool!
