201 - 220 of 365 Posts
· Zero felonies. One deportation.
Discussion Starter · #202 ·
Woahhhhhhhhh, so much..........CANDY
Speaking of candy, I wish more companies sent candy with orders.
Can't wait for my boxes of parts to start rolling in. Keeping the bay the same color or going to change things up a bit?
Its a great feeling, but my wallet is in pain!
I'm not sure about colors yet. I kind of have an idea about which color I'd like for the car, but that could change at any moment. I'm pretty indecisive, so I'd rather not say something and take it back 100 times.
Sent from my iPad using Tapatalk
· (⌐■_■)
Re: Tree's Roadster
I took a quick look at them the other day. I will be able to use about half of the little screws in the original spot. I'm thinking about using a resin to make my own mounting points similiar to the OEM ones and using a small self tapping screw. That way, if it works as I plan, it's a very OEM approach.
I've also heard of people using an epoxy to make new mounting points for the door card uppers. Seeing the door panel in white looks sort of good, could be a look of it's own on a white car.
I think that's what I plan on doing too - I found this as I'm starting to compile everything I need to redo mine
http://clubroadster.net/vb_forum/21-interior-sponsored-rev9-autosport/103746-diy-door-card-repair-rs-door-pulls.html
Discussion Starter · #206 ·
Greyhound's hours are stupid. Only open 9am-12pm on Saturday and everyday during the week they close before I'm out of school. I took my lunch break early today and booked across town to make it there before they closed.
This happened today. <3
New wheels by Austin Rajki, on Flickr
I've always been a fan of TE37s, but I can't afford them. So I got a nice, wide functional wheel that reminds me of them. They should fill out the flares pretty good!
I will post more pictures after work. :)
Discussion Starter · #212 ·
This may be the first bit of your build I'm not totally pumped on. Don't let it stop you though, the only opinion that matters is yours, so keep on rocking!
I'm thinking we'll have to see how they turn out mounted up. I'm not keen on 17s on a miata myself, but I've been surprised before. Keep rockin it Tree
Hopefully they turn out as I plan and don't have the Donk look to them.
Discussion Starter · #213 ·
Well I finally had time today to open the wheels up.
As you probably would have guessed they are NOT the truck wheels on the box, but instead are these:
Ready?
Dirty Work Meister CR01 by Austin Rajki, on Flickr
Work Meister CR01 3 piece wheels
15x9 +7 in the front
15x9.5 +1 for the rears
As you can tell they were pretty dirty
I gave them a shower to clean them up
Bath Time by Austin Rajki, on Flickr
All clean :)
Those aren't scratches. It's reflections of the grass
The lip on the fronts. Using a dollar bill because that reflects my bank account right now.
Work Meister CR01 Lip by Austin Rajki, on Flickr
3 piece welded goodness.
The lip on the rears is a little bit wider.
Fronts compared to rear.
And the set. Still need a good cleaning compared to a rinse. I'm going to buy a Mother's Powerball to get in all the tight spots. Cleaning between the bolts won't be the easiest thing.
Puppy :D
Dog Dish by Austin Rajki, on Flickr
