Tree's V8 Roadster
42126 Views 364 Replies 56 Participants Last post by  humming
Drivetrain:
Chevy 5.7L LS1 from 1998 Corvette
Fully ported and polished heads
Comp Cams 231/234 .619''/.612'' 111 LSA Billet Camshaft
Comp Cams Cam Lock Plate
ARP 2000 Rod bolts
ARP Head Bolts
ARP Crank Pulley Bolt
OEM GM Racing Division Lifters
OEM GM LS2 Timing Set
Manley Pro-Flow Race Valves- Intake and Exhaust
Comp Cams Trunion Retrofit Kit
0.060" Ford Rocker Shims
Comp Cams Racing Valve Locks
.675 PRC Dual Sprung Valve Springs
PRC Titanium Valve Retainers and Seats
Comp Cams Titanium Sprung Valve Stem Seals
Mellings High Pressure Ported Oil Pump
Texas-Speed Chromemoly Push Rods
All New OEM GM Gaskets/Seals/Head Gaskets
Mahle Perfect Circle Piston Rings
LS6 Valley Cover/PCV Conversion
Complete cruise control and A/C delete
ATL 15 Gallon Fuel Cell
Brakes, Suspension and Wheels:
Work Meister CR01 Wheels
15x9 +7 Front
15x9.5 +1 Rear
Depowered steering rack
Chassis:
Harddog M1 Hardcore Hardtop Double Diagonal Bar w/built in harness bar
Flyin' Miata Frame stainless steel Rails
Interior:
Bride Vios 3 Seats (replicas for the time being)
2 Garage Star Seat Rails
2 Pole Position Keys
Custom Door Cards
Exterior:
OEM Hardtop- No Headliner or Defrost
Tuckin99 N2 Fender Flares
APR GT3 carbon fiber mirrors
Slick Auto mirror mounts
161 - 180 of 365 Posts
Re: Tree's Roadster
Power: 450-500 whp NA
Trans: T56 6 speed
Dang. Dang dang dang dang DANG. This is intended as a drift/track beast?
Re: Tree's Roadster
Talk to shaftmasters. They're just across the border in Michigan and can build you whatever you need for a driveshaft. They're building one for me for my swap.
When the time comes I will give them a call. Thanks!
Driveshaft shop will have axles ready to ship for ya and can make any driveshaft for your needs. There great to deal with
Thank you sir!
Just a fun summer car that I can daily drive on nice days. I plan on building it reliable enough to handle the drag strip and tracks for track says though. It'll handle abuse.
Re: Tree's Roadster
I went snowboarding again yesterday. On my way back I picked up some parts that arrived at my american address.
The one from Jegs is on the left, Summit Racing is on the right.
Packages by Austin Rajki, on Flickr
Candy <3 Thanks Jegs!
Contents by Austin Rajki, on Flickr
ARP 2000 Rod Bolts
ARP 2000 Rod Bolts by Austin Rajki, on Flickr
The chocolate covered gummy bears sound weird, but weren't too bad actually. The package tells you which color is what flavour, but they all look the same...
Chocolate Covered Gummy Bears by Austin Rajki, on Flickr
Between my engines lecture and my Fuels lecture my engines teacher was in the lab, so I was able to get some work done. I paid him the $350 for the lifters and I got to work. The main seal cover was a bit of a pain to remove because of the way the stand is, but I managed.
Main Caps Removed
Main Caps Removed by Austin Rajki, on Flickr
The main bearings weren't bad, but will be replaced. The thrust bearing had a few marks, but the crank was good.
Main Bearings by Austin Rajki, on Flickr
The old lifters and lifter trays are out as well. Unless things fall through, I have a buyer set up for them.
Lifters and Trays by Austin Rajki, on Flickr
Then after removing the timing assembly I was able to remove the crank and camshaft. For those of you who don't know, when storing a crankshaft for a long period to time it should be stored standing up to prevent warping. I bolted the flexplate onto it to prevent the chance of it falling over.
I pretty much worked my small lunch break away so I had to rush to class after that.
Table Top by Austin Rajki, on Flickr
Re: Tree's Roadster
i ordered my nrg 2.5 from jegs and i got the same gummies! jegs <3 500 posts!
Re: Tree's Roadster
I wish every company gave free food with orders. I'm waiting for the day I get a pack of Ramen noodles.
The most random thing I've received have been from Dan's Comp (BMX website). They included Schick Hydro 5 razor blades and air fresheners. Lots of them too. haha
Congrats on 500 posts btw!
Re: Tree's Roadster
People don't care about post count, they care about running engines!
What's the timeline for engine rebuild btw?
Re: Tree's Roadster
What do you mean by timeline of a rebuild? Not sure if I get what you mean, sorry.
Re: Tree's Roadster
He wants to know if you're getting it done in 3 weeks or 3 months. Please don't say 3 years. ;)
Re: Tree's Roadster
Top ramen ftw! Haha
Re: Tree's Roadster
This. I'm basically wondering when you'll have the engine done.
Here's my engine build timeline:
Week of Feb 23rd: Fix the dohickey.
March 31st: Install the thingamabobs and whatchacallits.
April 1: ?????
April 2: Profit
May 31st: Running engine!
Re: Tree's Roadster
Duh. Brain fart, I guess.
I have engines lab on Wednesday. I hope to have the rod bolts installed and measured. I may have to hone them depending on how much the bolts distort the rods. I also hope to measure the mains and cam bearing journals and order all the bearings for next week. Everything depends on how much lab time I have free to do my work after all the demos
I finish school in April so the entire long block will be done by then.
Re: Tree's Roadster
Damn Tree, I head out of the country for work for a bit and come back to see you doing badass things. Having grown up around displacement I cant help but be jelly of the ls. Perhaps Ill build something ridiculous with one once Im done with the miata build. For now Ill simply have to live vicariously through you amigo. Keep up the awesome work.
Re: Tree's Roadster
Woah good stuff in here.
I've always liked the idea of the getrag diff.
Maybe 8.8 is better idk.
Re: Tree's Roadster
Oh yeah, you were in Alberta or BC right? How was it?
You bring up a good point actually. Since my last post I've done quite a bit more reading.
I've heard good things about the getrag and honestly it seems like the getrag will suit my needs a little bit better.
As far as I know most, if not all, getrag are cast aluminum casing compared to the Ford which are cast iron except the few aluminum ones they made.
Getrag is smaller allowing for easier exhaust routing, plus I've read it's better for road courses (left and right turns)
Each diff has their pros and cons so I guess nothing is guaranteed until I buy something. I still have a lot of work and research to do before I'm ready for a diff anyways.
Sent from my iPad using Tapatalk
Re: Tree's Roadster
Im super excited for you! A v8 powered Miata is my idea of the perfect combination, imo. Wish i could do a long term miata project and maybe someday. I honestly would have never guessed this from the start based on your "im a broke college student" claim, so congrats! :icon_cheers:
Re: Tree's Roadster
Ablerta Calgary yeah. It wasn't bad, but I was there for work not fun. The first trip was for 3 weeks and I managed to get 1 day off, which I used to head out to Sunshine Village and ski for the day. Scenery was stunning. Last trip should be this Sunday for anywhere from one to three weeks depending on how things go on site. More money for the project!
Re: Tree's Roadster
I've dreamt about a V8 Miata just about as long as I've wanted a Miata, which has pretty much been forever. I never, in a million years, would have thought I would be building one.
Good to hear you got to enjoy a day up there! Sunshine Village is amazing. Lots of fun runs, good terrain park, plus they have a "Peak to Parking Lot" run which is fun. Back in 2010 I went to Banff for a 9 day snowboard trip with my Uncle. We went to Sunshine Village 3 times in that time and went to other mountains other days. Heli skiing is unbelievable! We got in a helicopter and they flew us out to a remote mountain top around 9pm. We were above the clouds! 4 feet of fresh powder the entire ride. Experience of a lifetime for sure! The scenery there is gorgeous! Here is one of the shots I have from the peak at Sunshine Village.
Sunshine Village. Banff Trip 2010 by Austin Rajki, on Flickr
I need to go back. Those 9 days were easily one of the best times of my life. Hopefully you get to enjoy another day on the town on your next trip up. I'm also looking forward to seeing where you take your build!
Re: Tree's Roadster
Helicopter? Wow!
20 years ago I went to Banff with my dad, my sister, dad's new wife, and my half-brother who was basically a toddler. None of us ski. I'm not sure why dad wanted to go to Banff. But it was beautiful. Between early bedtimes, late mornings, afternoon naps, we headed outside for minutes at a time! ;)
11
Re: Tree's Roadster
Today I removed the cam bearings from the engine
Removing Cam Bearings by Austin Rajki, on Flickr
Cam Bearings Removed by Austin Rajki, on Flickr
And the core plugs
Core Plugs by Austin Rajki, on Flickr
And here is the bare block.
Bare Block with Gasket Material by Austin Rajki, on Flickr
The gasket material residue needed to come off the deck surface so I used this handy tool to help out. For those that don't know- this engine is 0 piston to deck clearance so I had to be really careful not to scratch the deck surface. Any knicks or gouges wouldn't be easily repairable other than welding or hoping the gasket can make up for it.
Gasket Material Removed by Austin Rajki, on Flickr
Then I placed the block into the parts washer for half an hour.
In the Parts Washer by Austin Rajki, on Flickr
When the block was in the parts washer I removed all the rings from the pistons
Piston Rings Removed by Austin Rajki, on Flickr
and disassembled the rods in preparation for cleaning and ARP install
Opened Rods by Austin Rajki, on Flickr
When the parts washer was done I noticed that one of the bell housing bolts had damaged threads, so I ran the tap through it to repair it. I ran the tap through all the other bell housing bolts just to double check that they were all clean and damage free. All the threads were perfect after that. :)
Tapping Bolt Holes by Austin Rajki, on Flickr
Once the bell housing bolts had the tap run through them I remounted the engine on the stand. I also wiped down the cylinder sleeves with penetrating oil to prevent them from rusting.
It's so clean. Cleaner than pictures do it justice. <3
Clean Block by Austin Rajki, on Flickr
My teacher also brought my lifters in for me. I didn't even get the chance to open them up. This is the warning on the box. OEM GM Racing Division Lifters. I've read about these being rated for 10,000 RPM without failure.
GM Racing Lifters by Austin Rajki, on Flickr
Re: Tree's Roadster
so when are we racing?
