Hi everyone!
I´ve been following this forum since 2008, but have never posted. I´m finally introducing myself, my name is Jean and I´m from the sunny and warm Mallorca, Spain. I do own a Miata 1.8 Touring NBFL (2003), color Emerald Green (18J) with a hardtop and have done some basic modifications to it.
Unfortunately in January 2010, a big wheel came out from a truck and went rolling for 150m till it crashed onto the complete left side of the car… so the car still in the garage being repaired and painted completely.
I will upload some pictures of my Miata once it comes out from being repaired and painted.
_____
_____
10th Anniversary Front Strut Bar + Beatrush Oil Filler Cap.
Beatrush Rear Strut Bar.
Borla Dual Sport Muffler.
Small rear mudguards, clear side reflectors, Shocks KYB AGX (4 positions) + Springs H&R & 195/50/15 Yokohama Parada Spec-2 82V.
Interior:
Cheanged my OEM interior for the Phoenix one (Brown leather seats, steering wheel and door panels).
Nardi wooden gearshift knob, handbrake and dash kit.
Chrome vent andhazard S2000 Start Engine button rings.
Kuda mounting base.
Black leather gear & handbrake gaiters and black leather gauge hood.
Miata carpet floor mats.
Sound:
Harman Kardon Drive + Play base dock.
Grom Audio Auxiliary (AUX-IN) interface adapter for MP3 player and iPod.
Changed OEM interior for Phoenix one + Nardi steering wheel & pedals.
Beatrush Hardtop Side Latches + Winziger Bolt set.
Adjustable PowerCard Pro (PC Pro), PowerCard Timing Controller with harness plug n' play 99/00 & TurboXS Knocklite.
"T" for Powercards.
AEM THRU BOOST & UEGO WIDEBAND.
Single DIN radio slot triple 52mm gauge holder "Black".
BLITZ VGTT Turbo timer.
Basic Modifications:
. Electronic: BLITZ VGTT Turbo timer.
. Engine: NGK IRIDIUM IX SPARK PLUGS KIT and MAGNECOR 8 mm SPARK PLUGS WIRES.
. Engine: Clutch Spec Stage 2+ & Spec Aluminum flywheel & SS Braided Line.
. Engine: MiataRoadster short shifter kits (removed Beatrush shift lever collar, prefer the Delrin one from MiataRoadster).
. Engine: Beatrush Oil Filler Cap.
. Engine: Nipple for oil pan.
. Engine: Mazdaspeed mounts.
. Engine: S2000 Start Engine button.
. Exhaust: Borla Dual Sport Muffler.
. Exterior: Small rear mudguards.
. Exterior: Front & rear Ryokurob Black NB Tow-Hooks.
. Exterior: Moss Black power coated fuel lid.
. Exterior:White-clear Black bumper side reflector & side repeaters.
. Exterior: Front black grill.
. Hardtop: Mazda Miata Hardtop color Emerald Green 18J with Smoked window.
. Hardtop: Beatrush Hardtop Side Latches.
. Oil: Gear box & transmission Redline Oil MTL.
. Oil: Differential Redline Oil 75W90.
. Oil: Engine Mobil 1 5W40.
. Interior: Changed normal Nardi steering wheel for the Phoenix Nardi one.
. Interior; Changed OEM black interior for the Phoenix brown leather one.
. Interior: Changed the plastic interior for the Nardi wooden gearshift knob, handbrake and dash kit.
. Interior: Changed the OEM leather for new black leather gear/handbrake gaiters, armrest and black leather gauge hood.
. Interior: New Miata carpet floor mats.
. Interior: Phoenix aluminum pedals (add-on).
. Interior: Led dome light + led interior light kit DIY based on http://www.miatamania.com/graphics/products/instructions/159-940.pdf
. Lighting: Added a pair of fog lights and lights to the side reflectors (like the US models).
. Rims: 15” stock.
. Sound: Harman Kardon Drive + Play base dock and a Grom Audio Auxiliary (AUX-IN) interface adapter for MP3 player and iPod.
. Strut Bar: 10th anniversary front Strut Bar (Japan).
. Strut Bar: Beatrush Rear Strut Bar.
. Suspensions: Shocks KYB AGX (4 positions) + Springs H&R.
. Tires: 195/50/15 Yokohama Parada Spec-2 82V.
. Washer: Cappuccino bottle.
Owned but not installed yet:
. Brake: calipers + pads from RX-7 FC3S or FD3S 4 piston calipers (front), might add up the rear too, heard they are plug n play.
. Brake lines: Kit of stainless steel TDR brake line.
. Differential: Polyurethane mounts.
. Electronic: Adjustable PowerCard Pro (PC Pro), PowerCard Timing Controller with harness plug n' play 99/00 & TurboXS Knocklite (on sale, looking forward to get a MS).
. Electronic: 10MM 4mm BRASS T PIECE HOSE JOINER CONNECTOR 3 WAY for Powercards.
. Electronic: AEM THRU BOOST + UEGO WIDEBAND + OIL TEMP 52mm gauges.
. Engine: EMUSA automotive Turbo 1.8 manifold for T25.
. Engine: Turbo Garrett CA18DET T2525.
. Engine: Billet Aluminum Flanges/Adapter for T25 turbo.
. Engine: Gates blue Racing Timing Belt.
. Engine: Intercooler V-Mount.
. Engine: Turbosmart BOV Kompact Dual Port - 34mm.
. Engine: NGK BKR7EIX-11 SPARK PLUGS KIT (for turbo).
. Engine: Mini air filter.
. Engine: Oil cooler sandwich adapter.
. Engine: K&N OIL FILTER.
. Exhaust Pipe: 2.5" - 64mm Exhaust Flex.
. Exhaust Pipe: Lambda Sensor Boss Nut For Exhausts (M18 X 1.5).
. Exterior***: Small air side sills and headlamp bezels (original Mazda parts) also in Emerald Green.
*** Has anyone installed those small air sides sills... didn´t know I had to drill the car?
. Sound: Double Din Radio face plate.
Should be ordered between 2011 and 2012:
. Bars: M2 Hard Core Hardtop '99 - '05 (M2) or TR LANE GPV + harness bar.
. Brake: rotors most probably: Audi 80 or Mini 290mm with modification.
. Engine: Silicone Radiator Hose + Silicone tube parts.
. Exhaust line: Complete 2.5" pipe.
. Hood: black Mohair hood.
. Rims: 15/16” OZ Racing Ultraleggera (Still deciding the color: Matt Black or Matt Graphite Silver) or 15/16” Rota Grid look good too.
. Sound: Becker Indianapolis Pro 7952.
. Tires: Toyo Proxes R1R.
P.S: I would like to thanks Ben, Luis & Mikel for helping me with this project =)
_____
_____
Interior:
Chrome vent and
Kuda mounting base.
Sound:
"T" for Powercards.
. Exterior:
. Rims: 15” stock.
