My 1999 Mazda Miata is having some problems I can't seem to diagnose....
It is real rough to start, it will crank hard and strong forever, but won't start unless I push the throttle in and out a couple times at the right moments. Then after it starts, it will idle correctly then after a while it will drop to 400 revs and if I don't touch the throttle it will stall. If I drive it around, and let off the gas, the revs will most of the time drop to 400 and stall. However.... if I keep on the gas, and do a steady speed, the car runs like normal. If there's any drop in performance it's extremely slight, I can't tell a difference.
I was running the heater everywhere I went and managed to do 100 miles on the car at night and the car held steady. Any time i turned the AC on it would overheat after 30 seconds.
I took the car into a cheap mechanic and he found the heater core hose was blown, he rerouted the heater core.... and still it has the same problems. I have not used the A/C though since this change.
Thoughts? Does this sound like a blown head gasket, a lot of people have been saying this is not the case?
After looking around the options I've found could potentially be:
Head Gasket
Catalytic converter clogged
Crankshaft sensor
Camshaft position sensor
Main Relay
The problem is.... why would it overheat if it was anything except the head gasket? But if it were a head gasket.... wouldn't there be more problems?
Are all of these potential options I should check?
Head Gasket
Crankshaft sensor
Main Relay
