1 - 2 of 2 Posts
It just came to my attention that my turn signals turn on when my brake lights are on. They apparently still flash when I use my indicator. I've done some searching and kinda am thinking that there's a bad ground somewhere. I also read that the brake bulb might not be the correct "1156" bulb, and might be a "1157", which also technically fits, but is not the proper one. However, this issue is pretty new and I haven't swapped out my bulbs, so I'm throwing that possibility out.
Has anyone else run into this? Can anyone help save me some time & point me to where the grounds for the brake lights are located? I've not had to chase down a bad ground before, I'm guessing it's literally finding where items ground to, unbolting the bolt, cleaning it & reattaching everything. No?
1 - 2 of 2 Posts
