1 - 8 of 8 Posts
Premium Member
You normally dont know, this part exists from your other cars and you have to change them on your miata every year or two. Heat /trackdays/ and mileage speed up the process even further.
Changing the shift boot is not only expensive, but also annoying, as bad smell and noise gets introduced into the passenger compartment.
The Jass Performance uprated upper shift boots are direct replacement, provided with stainless fitting hardware. They are designed to last for as long as the car rolls, already tested for years on fast roads and track. Additional thick heat resistant insulation is there to ensure both - 100% sealing plus additional noise and heat insulation.
Each is $54 + shipping. Please PM with ZIP code for quote, shipping options are available too.
wait.... is this suppose to be used with or without the OEM leather shift boot? This is quite tempting.
Premium Member
Discussion Starter #5
LOL, cheers guys. Lots of people tend to use them already without the leather gaiter, however its made and meant to be direct OEM replacement and will integrate perfectly with it.
Premium Member
Discussion Starter #6
And mentioning leather gaiter, I have these gear knob and handbrake gaiters available with red and black stitching, which if needed I could add to the shift boot orders.
The shifter gaiter comes with plastic ring, which gives a nice finish if used with certain gear knobs.
The plastic trim underneath needs to be reused however, dont have them, as they are not really needed.
Premium Member
Discussion Starter #7
A little reminder at the right moment: as you already have learned the british pound got nearly 20% weaker after the Brexit referendum, which automatically made all Jass products 20% cheaper.
Should you have considered any purchase from www.jassperformance.com - now is a right moment.
There are already plenty US orders from the morning.
Nice heads up!
1 - 8 of 8 Posts
