using nearly full length higher rate springs w/ NB upper shock mounts for lowering
852 Views 2 Replies 2 Participants Last post by  OCRedRoadster
Hi all - I am considering using higher rate, approximately full stock length springs (maybe up to 1/2" shorter) with NB upper shock mounts to lower the car around 1/2" while maintaing more travel. I don't know what springs would make this work still just investigating it.
Or...perhaps not using the NB mounts and getting some 1/2" spacers under some lowering eibach springs to help regain some travel from lowering.
I have AGX shocks.
Has anyone tried this or heard any of this being done? Anyone ever tried FatCatMotorsports modified NB upper shock mounts or their bump stops? http://www.fatcatmotorsports.com/FCMmounts.htm
How does everybody deal with the lowering vs. lack of travel? I origianlly thought I could get by with stock springs but no longer feel that way. I want to lower and stiffen up.
Thanks for any comments
1 - 3 of 3 Posts
have you peeped the new FM springs? the drop on those isnt aggressive, keep in mind the top mounts will drop you 1/2" as well
No I didn't see the new springs I will check them out, thanks.
1 - 3 of 3 Posts
