I think my valve seals are bad. Here is why...
When driving on the high way at normal speed, RPMs ~3K-4K, if i let off the gas and let the engine stay in vac ~-28psi, and press the gas again i get large plume of smoke for 1-2secs, then its clear. High RPMs...no smoke.
The car WAS boosted, but its not NA. I was having the same problems, but it was MUCH worse with the turbo, turned out to be a bad turbo seal and it filled me exhaust with oil. But now its back but not nearly as bad.
Can I change the valve seals my self at home?
