1 - 20 of 147 Posts
Beggars can't be choosers.
Might as well double the spark plugs too
Are you taking EGTs or O2 readings from each cylinder? Excuse my ignorance here but, why?
Discussion Starter #12
MotoIQ did this on their miatabusa project.
Might be worth it if you can get each cylinder running equally with the ITBS
right now I'm doing to study and research the differences in fueling per cylinder.
Later on when the ecu developer implements per cylinder changes I can make more use of them or if I change to a different ecu that provides that ability.
I still plan to add in some thermocouples later and a exhaust pressure sensor as well
Super Moderator
Have you considered modifying your fuel system to incorporate 4 fuel pumps (1 for each cylinder) so that each injector can achieve maximum pressure efficiency?
1 - 20 of 147 Posts
