1 - 4 of 4 Posts
This may be vague but I'm hoping someone else had this before.
I get this weird WhoooOOIP noise from around my passenger wheel well. It doesn't happen alot, but i can't figure out what it is. (It seems to only happen when i have a cute girl in the car) I'll try to get a video of it, but its not reproduceable so that makes it kind of hard. Has anybody every had something similar to this?
Discussion Starter #3
It doesn't really sound like a rubbing problem but i'll check it out. Thanks for the suggestion.
Check your tires to see if there is any wear indications. Also check everything in your wheel well. Walls, suspension, cables, everything.
Also "WhoooOOIP" doesn't quantify as descriptive brah... video this ****.
What I usually do, is I take off my entire wheel and look at my tire at all angles, once I find any indications of wear, I look in the wheel well, sometimes you won't so I throw my head inside the well anyway to see any potential signs of rubbing..
I shredded the entire front half of the wheel cover inside my wheel well in the FD once I switched to wider tires.. **** was dope.
1 - 4 of 4 Posts
