1 - 5 of 5 Posts
So I was heading to Ocean City and had gone about 80 miles out the the 160 between lancaster and Ocean City. So all of the sudden my headunit blinks a few times then dies. Then my airbag light started blinking. So I moved as far from the wheel as possible then . Then the car started to feel like a dirtbike with the choke on, and the tach was going insane, floating at what would be 10,000rpm and just staying there and then floating around more. So I turned around and started heading home - It got to the point where I couldn't pull away from a stop light so I pulled over. After sitting for about two minutes my car had enough juice to pull away. I had to stop like this about 10 times at least the way home. BARELY made it back - almost couldn't make it over the hill with a stop light 5 miles from my house - of course the light was red. And now it won't start. So - *** is going on? It seems like the belt / pully might be losing contact with each other when it gets over a certain RPM though that would be weird. Maybe its just the alternator taking a crap? But does that affect how the motor runs? I don't know a whole lot about electrical systems at all... So what do you guys think?
Oh and another important detail - when I bought the car the guy was like HEY! I EVEN PUT A NEW BATTERY IN IT! Which kinda made me think... why did it need a new one? I think I know now!
PS I also posted on m.net but it got moved out of the NA section and go figure, still no responses.
bad mother f......
Its alternator time for you!!!!!
Premium Member
Those are some strange problems. I too think it's probably the alternator. There are shops that can test the alternator to see if it's bad, you may want to try that before you get a new one and spend the money there.
-Ryan
1 - 5 of 5 Posts
