1 - 20 of 94 Posts
Hello,
I know some of you started posting what you would like, so I set up a thread for it.
I will be subscribed for this so post away.
Jason
^^ but with a different canister , and a longer Tip after the canister, not angle cut. but angled upward
Fender braces, at competitive prices , like BossFrog.
adjustable Rear Upper control arms to dial out camber .
Like the TC Sportline prototype. ( i dont have a link) search on CR
more cool stuff
YES!
But make those fender braces more tuckin' than frog. I can't stand the frog ones. Nice simple crossbraced ones.
Brackets that would allow me to use the calipers from an FC rx7 on the front of my NB.....
can you make a really cheap randall intake out of plastic that looks OEM
ADJ control arms +3!!!
bad mother f......
Coldside cold air intake
gauge pod for top of dash
Finger lickin' good...
3" St.May-style shotgun exhaust w/ minimal bends
1. Mounts to mount the Outlaw calipers onto stock NA8 or NB sports rotors:
http://www.clubroadster.net/forum/viewtopic.php?t=7783&highlight=outlaw+calipers
2. height adjustable pillowball uppermounts that allow you to adjust the ride height without crawling under the car
3. meter pod that goes on the meter hood (similar to the Garage Vary piece but for LHD obviously). Or a angled double or triple meter pod that goes on the center top of the dashboard location just like Stealth suggested.
4. A tasteful (not crazy outlandish) bolt on extraction vent for the stock hood
5. A tasteful (not crazy outlandish) bolt on extraction vent for the hardtop. It has to include some sort of interior panel also to cover the exposed fiberglass cutout
6. A tasteful (not crazy outlandish) bolt on extraction vent for the side of the fender.
7. An aluminum tank to replace the factory plastic radiator overflow tank.
8. A rear diffuser that goes under the stock (or cut) rear bumper
*+3 on the cold side intake, maybe randall type?
*Nopro style ebrake bar (not just handle)
*cheap heat shield
*cheap plastic radiator cover thingy for better flow (for NA)
1 - 20 of 94 Posts
