1 - 18 of 18 Posts
hay guys im new to this club
and i needed some help i was thinking about getting some wheel spacers to make the car look a bit cooler ..but im not sure what to go with .....i know that the bolt pattern on NA Miata is 4x100 and i was thinking of going with 32mm(1.25in) IS THAT TO MUCH
OR SHOULD IT LOOK COOL
Accepting donations.
With a 0 offset.
Find out what offset your wheels are and get the spacer size to make it zero.
It will look dumb with skinny wheels, but whatever will make you cool right?
If you look at the car more from the front you can really see the change..but no complaints very happy with them
Functionally formed.
Any rubbing issues? What brand spacers did you buy?
Reason for all the questions is because I'm about to take the same plunge. 25mm spacers with some 15x7 +38 Kosei's. I'm lower than you though, I'll probably go with some 195/45's.
Spyder you will be fine, you will be at +13 I doubt you will rub much.
Yeah just get them, I was thinking about getting new wheels but this was a good alternative for me, makes the car look so much more different. And yours being lower it'll look alot better
1 - 18 of 18 Posts
